Add an Annotation to an Alarm Expand the Fault Manager slider and select Alarms. In the alarms table, click the alarm to which you want to add explanatory note and click Edit. In the Edit annotation dialog box, add your explanatory note about this alarm in the Annotation field. Click OK.
