Disk Usage
Use the Disk Usage monitor on a selected SDM server node to check if disk usage exceeds the 50 and 90 percent thresholds and inspect disk storage usage by gathering statistics for total disk storage, used disk capacity, and free disk capacity. You can also display the SDM server directory size and view the partition on which the directory is located. For example, a database directory might be located on a different partition from other directories.
