Summary
- From the menu bar, select Tools > Health Monitor.
- In the Health Monitor Console pane, select Disk Usage from the Select Monitor drop-down list.
Select the SDM server node IP address from the
Select Source drop-down list (if the node is a member of a cluster) or retain the default value if the node is a standalone node. In the
Summary tab, the following table describes the storage statistics fields:
Name Description Cluster member The node name. Path The directory path where the node is installed. Status The following status partition space status conditions can occur: - Normal—The partition space is below the minimum threshold value, which is fifty percent (default).
- Warning—The partition space is at or above the minimum threshold value of fifty percent (default), but below the maximum threshold value of ninety percent (default).
- Critical—The partition space is at or above the maximum threshold value of ninety percent (default).
Capacity The total partition disk space in gigabytes (GB). System Used Space Total amount of disk space being used. Free Space The remaining disk space in GB. Percent Usage The percent of used disk space for the entire partition.
