Plugin Tasks
Use the following tasks to perform product plugin actions in Oracle Communications Session Delivery Manager.
The following figure shows the life cycle of a plugin.
Figure 3-1 Plugin life cycle
When you perform upload, install, uninstall, replace, and delete plugin actions on one node, the other nodes of the cluster are signaled to apply the same action. All users who are logged into a node, other than the one where the action was initiated, should refresh their browser to have their GUI updated for the new functionality. If some functionality is still not available, re-login to the node.
