Setting Route Manager Privileges
Use this task to apply user-group privileges for Oracle Communications Session Delivery Manager configurations.
Depending on your user privileges in Oracle Communications Session Delivery Manager, you can enable privileges to configure route set groups and templates, perform backups or restore route sets, and perform route set operations on devices.
- On the navigation bar, select Security Manager > User management > Groups.
- In the User Groups pane, select the group you want to modify from the User Groups table and click Edit.
In the expanded group pane, click the
Configuration tab and expand the
Route Management Central configuration folder and expand it to expose the following folder items:
Name Description Configure route set item Click this item row to activate the Privileges drop-down list to do the following operations: - Select Full to enable the Route Sets, Route Search, and Route Set Compare tabs to appear. These tabs are used to add, configure and manage route sets, and retrieve LRT files.
- Select View to view the route set configuration only.
- Select None to disable route set operations and make them disappear from the GUI.
Configure templates item Click this item row to activate the Privileges drop-down list to do the following operations: - Select Full to enable the Import Template tab. This tab is used to configure the templates that are used to map CSV file columns to route properties, and import CSV files.
- Select View to view configuration templates only.
- Select None to disable template operations and make them disappear from the GUI.
Backup/Restore item Click this item row to activate the Privileges drop-down list to do the following operations: - Select Full to enable the Route Set Backups and Route Set Scheduled Backups tabs. These tabs are used to create backup files of the route set(s) and restore the backup files to the device.
- Select View to view backup files of the route set(s) only.
- Select None to disable backup operations and make them disappear from the GUI.
Device operation item Click this item row to activate the Privileges drop-down list to do the following operations: - Select Full to enable the Device Route Sets, Associated Devices, Device Route Set Updates, and Update Task History tabs. These tabs are used to add route sets to devices, view the route sets associated with each device, update route sets, and update task histories.
- Select View to view route set device information only.
- Select None to disable route set device operations and make them disappear from the GUI.
- Click Apply.
