Apply User Group Privileges for Device Groups
Use this task to apply user-group privileges for device groups that appear on the Device Manager slider.
- Expand the Security Manager slider and select User management > Groups.
- In the User Groups pane, select the group you want to modify from the User Groups table and click Edit.
- Click the Device groups tab.
In the
Device groups box table, complete the following fields:
Name Description Include children check box (Optional) Check the check box to select all children of the device group. Next select either Set all to None or Set all to Full have no privileges or full privileges respectively for the children of the device group. Home item (Default device group) In the Privileges column drop-down list, choose the following user group privilege options for items in the Device groups box table described below: - Full—(Default) Allowed to perform device group operations.
- None—Users do not have authorization to the device group.
- View—Users can view the group on the Device Manager slider, but cannot perform any operations such as adding or deleting a child group.
The Preview box displays the device group based on the privileges that are assigned (Full, View). - Repeat the previous step for other device groups (if there are any).
- Click Apply.
