About Net-Net Central Traps
The trap event setting allows you to override the core SDM default event trap severities and customize them.
- Expand the Fault Manager slider and select Trap event setting.
- In the Select dialog box, select the SDM trap group row from the Trap groups table and click OK.
- The following table describes the SDM product event types and a description that references its respective trap. If you need to customize the severity level of this trap, see the Customize Alarm Trap Severity Levels section for more information.
| Trap | Description |
| apEMPluginDuplicatedRestPrefixName | The trap is generated when there is a plugin installation attempt that has the same name as an existing REST API prefix name in the system. |
| apEMPluginFailedInstall | The trap is generated whenever an element manager (EM) product plugin failed to install. |
| apEMPluginFailedInstallClear | The trap is generated whenever an EM product plugin failed installation status is recovered. |
| apEMPluginFailedUninstall | The trap is generated whenever an EM product plugin failed to uninstall. |
| apEMPluginFailedUninstallClear | The trap is generated whenever an EM product plugin failed to uninstall status is recovered. |
| apEMSActivateFailure | The trap is generated when SDM fails to activate a configuration, whether initiated from the SOAP XML API or the SDM GUI for the save/activate or activate operations. |
| apEMSNodeUnreachable | The trap is generated when the status of a node changes from reachable to unreachable. The trap contains the node ID of the device and the time of the event. |
| apEMSNodeUnreachableClear | The trap is generated when the status of a node changes from unreachable to reachable. The trap contains the node ID of the device and the time of the event. |
| apEMSSaveFailure | The trap is generated when SDM fails to save a configuration. The trap is generated by a save failure whether initiated by the SOAP XML API or SDM GUI for the save/activate, save, or offline save operations. The trap contains the node ID of the device, the start and stop time of the save configuration attempt, and the user initiating the save operation. |
| apEMSDiscoveryFailure |
The trap is generated whenever an error is detected during server node discovery. |
| apEMSInvalidConfigDiscovered |
The trap is generated whenever an invalid configuration is retrieved from a node. Additional information about the validity failure is available in the discovery log. |
| apEMSInvalidConfigInventory |
The trap is generated whenever an inventory check was performed and failed. |
| apNNCReportingHdrAggregationFailure | This trap is depricated. Use the apNNCReportingHdrAggregationLagFailure trap. This trap is generated when an SDM reporting HDR aggregation task fails to keep up with incoming HDR data. |
| apNNCReportingHdrAggregationLagFailure | The trap is generated when an SDM reporting HDR aggregation task fails to keep up with incoming HDR data. |
| apNNCReportingHdrAggregationLagFailureClear | The trap is generated when a previously failed SDM reporting HDR aggregation task is now able to stay current with incoming HDR data. |
| apNNCReportingHdrDetectionFailure | The trap is generated whenever an SDM reporting HDR detection task failed. |
| apNNCServerUnreachable | The trap is generated whenever an SDM server is determined to be unreachable by another an SDM server configured in the same cluster. |
| apNNCServerUnreachableClear | The trap is generated whenever a previously unreachable SDM server is determined to be reachable by another SDM server configured in the same cluster. |
