Manually Purging
  1. Expand the Security Manager slider and select Audit log > Purge.
  2. In the Manual Audit log purge dialog box, click the calendar icon next to the Purge audit log records prior to field and choose the date from the calendar prior to which you want audit logs purged.
  3. Click OK.
