Database Group Replication HA Behavior in Multi-Member Cluster
| Activity | Description |
| Server startup | When an
Oracle Communications Session Delivery Manager server is started it joins the cluster as a replica and an election is held if there is currently no master. If the member ends up as a replica, then it is synchronized with the master during the initialization phase of the database service startup.
With the introduction of
Oracle Communications Session Delivery Manager, Release 8.0, use the following steps to start an
SDM server cluster:
| Master member failure | When the master fails or becomes partitioned from the rest of the members in the cluster, an election is automatically held by the remaining replicas to elect a new master. |
| Transactions (Quorum) | Transactions return successfully if a majority of the members in the cluster have replied that they received the replicated datasets. If quorum in replies from replicas is not achieved in a specific time period, the transaction fails. |
| Network partition | When a network partition exists between the members, only the members that can communicate with a majority of the members may elect a new master database. Members that can not communicate with a majority will enter READ-ONLY mode. Upon re-establishing network connectivity, re-elections take place and a master is elected while the other members revert to replicas. |
| Elections | In a cluster of three or more members, an election is won by the member with the simple majority of votes. The member that wins an election is always the one with the most recent log records. In the case of a tie, the member with the highest priority wins. |
| Rejoining cluster after shutdown for an extended period | If the server that needs to rejoin the cluster has been down for more than 24 hours, perform a hot backup on the host running the master database and restore the backup to the server that is down before restarting it. This avoids the potentially high cost synchronizing the server with the master during startup. |
