Session Delivery Manager Application Overview
Oracle Communications Session Delivery Manager is a network element management system that can be accessed through a graphical user interface (GUI), REST API interface, or SOAP API interface.
Once
		SDM is installed, you can access the following sliders:
Other sliders, such as the Device Manager, Configuration Manager, Performance Manager, and so on, will not be seen until you install a product plug-in.- Device Manager—Use this slider to configure device groups. The functionality of this slider is dependant on the product plug-in(s) that you have installed.
 - Security Manager—Use this slider to configure any security privileges that are specific to Oracle Communications Session Delivery Manager and the Oracle Communications Session Delivery Manager product plugin.
 - Fault Manager—View events, alarms, and trap summary data.
