Editing Fault Email Notifications
With appropriate administrator privileges assigned, you can edit fault email notifications.
- On the main menu, click Settings > Faults > Fault email notifications.
- In the Fault email recipients dialog box, select the email address you want to edit and click Edit.
In the
Edit email dialog box, edit the following fields:
Name Description *Email address field The recipient email address attached to the alarm severity. Severity drop-down list Select the severity level for this email notification. The levels are Emergency, Critical, Major, Minor, Notice, Warning, Info, Trace, Debug, and Unknown. Notify on clear check box Check the check box to send a fault notification on all clear events. This option is only available for the following severity levels: Emergency, Critical, Major, and Minor. - Click OK.
- In the success dialog box, click OK.
- In the Fault email recipients dialog box, the edited email address appears in the table. Click OK
