Change a User Password If you have administrative operations permission, you can change the password of a user. Expand the Security Manager slider and select User Management > Users. In the Users pane, click a user from the table and click Change Password. In the Change password dialog box, complete the following fields: Name Description Enter your password field Enter the password of the logged in user. Enter new password for user field The new password for the user. Confirm new password for user field The new password is entered again to confirm it. Click OK.
