Resetting Passwords
Pre-requisites: You must have the proper permissions to reset passwords.
- Expand the Security Manager slider and select .
- In the Users pane, click a user from the table and click Reset Password.
- In the Reset password dialog box, enter a new password for the user in the field provided.
- The dialog box indicates if you entered the new password successfully. Click OK.
