Deleting Groups
- Expand the Security Manager slider and choose User management > Groups.
- In the Groups pane, choose the (non-default) user group that you want to delete from the User Groups table and click Delete.
In the
Delete confirmation dialog box, click
Yes to delete this user group.
The user group is removed from the User Groups table.
- In the success dialog box, click OK.
