Privileges
You can apply privileges to user groups that you add to allow or deny all users within this user group the ability to perform certain operations. This includes items intended for use with separate application products. For the default LIAdministrators, administrators, provisioners, and monitor user groups, only device group privileges can be changed.
All user group privileges that are available through SDM are described in the following sections. You may not see some of these user group privileges in the Configuration, Device maintenance, Administrative operations, Fault management, Device groups, and Applications tabs in SDM until you install your product plugin.
