Apply User Group Privileges for Configuration
- Expand the Security Manager slider and choose User management > Groups.
- In the User Groups pane, select the group you want to modify from the User Groups table and click Edit.
- In the expanded group pane, click the Configuration tab and click the folder and subfolder sliders to expand the item operations list.
- Select the item row in the operation category table that you want to modify and click the Privileges column to activate the drop-down list.
In the
Privileges drop-down list, select the following user group privilege options for folders or items in the
Configuration tab table described below:
- Full—Allowed to perform administrative operations.
- None—Not allowed to perform administrative operations.
- View—Allowed to monitor only.
The fields described below appear if all features are enabled.Name Description Configuration folder Set privilege levels for all configuration operations. Device configuration folder Set privilege levels for all of the following user management operations accessible on the Device Manager slider. Configure services item Set privilege levels for host-in-path (HIP) firewall functions that are allowed to pass administrative traffic to the host. Configure interfaces item Set privilege levels for FTP, ICMP, SNMP, Telnet, and SSH interfaces. Configure NM controls item Set privilege levels for network management controls performance group pane. Configure security item Set privilege levels for the Security Manager features. Configure LI item Set privilege levels for lawful intercept features. Configure system item Set privilege levels for the configuration of system usage parameters. Route Manager Central Configuration folder See the Oracle® Communications Route Manager User Guide for Session Delivery Products for more information about privileges that you specify in this folder. Work order folder Set privilege levels for all of the following user management operations accessible for the configuration of work orders. Create work order item Set privilege levels for creating a work order. Execute work order item Set privilege levels for executing a work order. Load device item Set privilege levels for loading a device. Override lock item Set privilege levels for overriding a lock on a device. Transfer configuration view item Set privilege levels for viewing a configuration. Entitlements item Set privilege levels for viewing license details for an NF device. Update to device folder Set privilege levels for the following device configuration operation items in this folder. Save configuration item Set privilege levels for saving the configuration of a device. Save and activate configuration item Set privilege levels for saving and activating the configuration of a device. Activate configuration item Set privilege levels for activating the configuration of a device. Configuration archive folder Set privilege levels for all of the following configuration archive operations. Back up configurations item Set privilege levels for backing up configurations in the configuration archive. Restore configurations item Set privilege levels for restoring configurations in the configuration archive. Delete archived configurations item Set privilege levels for deleting configurations in the configuration archive. - Click Apply.
