Backup and Restore Database Servers
The following sections describe how to backup the application database on an SDM server that is shutdown (cold backup).
You must have system administrator privileges on the server to do a database backup.The SDM database and a separate database for reporting (if you are using Oracle Communications Report Manager with SDM) runs on each cluster node. During a typical database backup, the backup for each of these database is done on the master node and the backup file is stored on the node running the backup only.
