PreviousNextJavaScript must be enabled to correctly display this content
Standalone System
You can shut down the existing
SDM software version running on your system to install a new version of the software, restore a database or apply a software patch.
Log in as the nncentral user.
Change directory to the bin directory.
For example:
cd /home/nncentral/AcmePacket/NNC<version>/bin
Execute the
shutdownnnc.sh script. By default, the shutdownnnc.sh script detects whether the existing installation is a standalone or clustered system and prompts you with the option to shut down the entire cluster if no flag options are provided.
However, You can script an option ahead of time by adding -local for single nodes and -cluster to shutdown an entire cluster.
./shutdownnnc.sh
Shutdown back-end server
Do you wish to shut down the entire cluster (Yes/No)? Yes
