Backing Up with Server Shutdown
Use this task to do a backup the application database (Core DB), Oracle reporting database, and OCSDMDW reporting database on the shut down SDM server (cold backup) to a local directory path.
Next Steps
- Select and view the Heartbeat Summary table to check SDM cluster member node processes.
- Begin using
SDM. Use your web browser to navigate to the server login page by entering the host name or IP address, and port number in the web browser navigation bar. For example:
http://example.com:8080
In the login page, enter the administrator login name and password that you configured in the Configure User Account Passwords section.
