Backing Up with Server Running
Use this task to do a backup the application database (Core DB), Oracle reporting database, and OCSDMDW reporting database on the SDM server that is running (hot backup) to a local directory path.
Before you backup databases on the SDM server, ensure that you have system administrator privileges, and contact users to minimize or prevent them from using SDM during the backup.
Next Steps
- Select and view the Heartbeat Summary table to check SDM cluster member node processes.
- Begin using
SDM. Use your web browser to navigate to the server login page by entering the host name or IP address, and port number in the web browser navigation bar. For example:
http://example.com:8080
In the login page, enter the administrator login name and password that you configured in the Configure User Account Passwords section.
