Restore Databases
Use this task if you need to restore the application and reporting databases on your SDM system or cluster.
Next Steps
- Select and view the Heartbeat Summary table to check SDM cluster member node processes.
- Begin using
SDM. Use your web browser to navigate to the server login page by entering the host name or IP address, and port number in the web browser navigation bar. For example:
http://example.com:8080
In the login page, enter the administrator login name and password that you configured in the Configure User Account Passwords section. -
After the server starts (after the restoration of its databases), it attempts to synchronize all plugins installed on the local file system again. Select in the SDM GUI to ensure that all plugins are working properly in the Element Manager Plugins table.
