PreviousNextJavaScript must be enabled to correctly display this content
Saving Alarms Data
You can save event or alarm data in the content area to a comma-separated values (CSV) file that stores table data (numbers and text) in plain-text form.
Expand the
Fault Manager slider and select from the following options:
Events
Alarms
In the events or alarms pane, click
Save to file.
In the save dialog box, select either to open the file or save the file.
If you save the file, the file is saved to your browser's default download location.
