Help Menu
- Select Help > Help topics.
In the web page that displays for your plugin, select from the following default document links if
SDM installed only:
- Session Delivery Manager Administration Guide
- Session Delivery Manager Security Guide
If you have installed a product plugin, select its link under the Oracle Communications Plugin Help title. A web page displays for the product plugin and its documentation links.
Select Help > About to get SDM system and product plugin information (if it is installed) in a pop-up window.
