Settings Menu
Use the Settings menu to access the following selections:
- Faults—Configure faults, fault notifications, trap receivers and heartbeat traps.
- Alarms—Configure audible alarms, alarm colors, and configure how alarms are displayed in SDM.
- Edit Login Banner—If you have full administrative privileges, you can define the informational banner seen when a user logs into SDM. This banner can also be specified to contain a user compliance rule with terms and conditions regarding the use of the application.
