Tools Menu
Use the
Tools menu to access
the following selections:
- Passwords—Change the password you used to login to the SDM GUI. Refer to the Change Your User Password section in this chapter for more information.
- Health Monitor—View the health of each SDM system. Refer to the Monitor Session Delivery Manager Server Health and Disk Usage chapter for more information.
- Upload configuration schema file— A configuration schema provides a configuration model and information for a device. Refer to the Configuration Manager chapter in your Oracle Communications Session Element Manager User Guide plugin product documentation for more information about uploading a configuration schema file for a device.
- Server Diagnostics—Use this selection to view SDM server log information including how log data is collected. Refer to the Use Server Diagnostic Logs section for more information.
- Device association information—Use this selection to see how many devices are in use by the product plugin and its associated applications.
- Certificates—The SDM server can use trusted certificates (certificates validated by a CA or self-signed certificate) in its trust store. Refer to the Manage Transport Layer Security Certificates chapter for more information.
- Plugin Management— Upload and install a plugin product application, such as an element manager (EM). Refer to the Manage Product Plug-ins chapter for more information.
