Configuring Data Deletion Time Frames
- On the main menu, click Settings > Faults > Fault configuration.
In the
Fault configuration dialog box, complete the following fields:
Name Description *Clear events older than (days) field The number of days events are retained in the database before the events are cleared. The default value is seven days. Zero indicates no event data is cleared *Clear alarms older than (days) field The number of days alarms are retained in the database before the alarms are cleared. The default value is 14 days. Zero indicates no alarm data is cleared. *Duplicate trap filter interval (minutes) field The number of minutes for when duplicate traps are rejected for events and alarms. - Click OK.
- In the success dialog box, click OK.
