Specify a Criteria to Delete Alarms and Events The appropriate administrator privileges must be assigned to delete alarms or events. Use this task to specify one or more criterion for deleting alarms or events from Oracle Communications Session Delivery Manager. Expand the Fault Manager slider and select from the following options: Events Alarms In the events or alarms pane, click Delete by criteria. In the Delete event dialog box, complete the following fields: Note: When there is a high number of faults that are being sent from devices, a purge interval of 2 days for events and 7 days for alarms is suggested. Name Description Please specify the delete choice field Click to select either Delete all or Delete by criteria. Date from field Click the calendar icon and select the month, year, and day and click Today. Note:The chosen date to filter event data begins at 12:00 AM (midnight) on the specified date. Date to field Click the calendar icon and select the month, year, and day and click Today. Note:The date you select ends at 11:59:59 PM. Device field The source name for this device. Source IP field The IP address for this source device. Trap name drop-down list Select the trap name. Type drop-down list Select the alarm type. Severity drop-down list Select the severity level for this alarm or event. Click OK.
