Typical Installation
The Typical installation performs the minimal configuration required to run the Oracle Communications Session Delivery Manager server.
The following tasks are accomplished in the Typical installation:
- The setup program loads and installs the appropriate product plugins (if you are upgrading
SDM from a previous version).
If you are installing SDM for the first time, the appropriate product plugins must be installed after the SDM server installation. See the Manage Product Plugins chapter in the Oracle Communications Session Delivery Manager Administration Guide for more information. - You can configure passwords for the default user accounts.
- You can configure the global identifier
- You can either configure HTTP or HTTPS (recommended) on the Apache web server.
- You can configure the SNMP Trap Relay port for Fault Manager.
Verify you have the correct sudo password before continuing.
