Editing the sudoer Configuration File
You must specify limited privileges for an NNCentral user on the Linux server, so this user can administer Oracle Communications Session Delivery Manager operations on the server.
You must use
visudo
to make edits to the sudoer configuration file.
This file can only be edited using Linux visual text editor (vi editor) commands.
