About Creating a Report Manager Database Instance on the External Oracle Database
If you are using Oracle Communications Report Manager with Oracle Communications Session Delivery Manager, option 10 (Oracle DB OCSDMDW configuration) in the Custom Installation is used to specify the Oracle home path (ORACLE_HOME) and the credentials of the Oracle database user instance (OCSREMDW).
For more information about creating the OCSDMDW database instance, see the Create a Report Manager Database Instance chapter in the Oracle Communication Report Manager Installation Guide.
