System Requirements
Oracle has certified the following hardware ai
nd software server platforms as well as client requirements for use with Oracle Communications Session Delivery Manager.
Other hardware configurations might work with Oracle Communications Session Delivery Manager, but Oracle has verified the configurations listed here.
Oracle Communications Session Delivery Manager Server Requirements
  • CPU: 4-core 2.1 GHz processor or better
  • 16 GB RAM minimum, 24 GB RAM recommended
  • 300 GB hard drive minimum
Supported Operating Systems
Oracle supports the following installations of Oracle Communications Session Delivery Manager:
  • Oracle Linux 6.5, 6.6, 6.7, 6.8, 6.9, 7.0, 7.1, 7.2 64-bit.
    OpenSSL 1.0.1e-fips or later must be installed on your linux server in order to use the HTTPS service on the Apache web server. Most Linux distributions include OpenSSL as part of the OS installation. You can check the version on your system by using the following command:
    openssl version
    OpenSSL 1.0.1e-fips 11 Jun 2017
Oracle supports the following installations of Oracle Communications Session Delivery Manager with Oracle Communications Report Manager:
  • Oracle Communications Report Manager for Oracle Fusion Middleware 12c is supported on Oracle Linux (64-bit) 7.0, 7.1, 7.2, or 7.3
  • Oracle Communications Report Manager for Oracle Fusion Middleware 11g is supported on Oracle Linux 6.5, 6.6, 6.7, 6.8 only.
Client Requirements
  • Oracle recommends Internet Explorer versions 11.0 and later, Mozilla Firefox versions 43.3.1 and later, or Google Chrome version 56 and later.
  • A Flash player compatible with your browser that is installed locally.
  • If the server is not part of your DNS domain, the hosts file on each client must be edited to include the host name and IP address of the Oracle Communications Session Delivery Manager server.
Language Requirements
On the Linux server, ensure that the US English language UTF-8 character encoding method is specified.
