Revision History
| Date | Description |
| August 2017 | Initial release |
| October 2017 | Certain steps and examples were improved by making the SDM installation directory and software version number generic instead of specific in all examples. |
| November 2017 | A caution note was added to the Verify the Required SDM_localhost Entry is in the Hosts File section. |
| May 2018 |
| September 2018 | The Check the File Descriptor Count on Your Linux System section was added to the Pre-Installation Tasks chapter. |
