Start the Cluster Installation
You can install a high-availability (HA) cluster of SDM servers to ensure reliable, continuous data and operations by masking both planned and unplanned downtime and preventing single points of failure without compromising availability.
  1. Login to your server as root user.
  2. Navigate to the Oracle Communications Session Delivery Manager installation bin directory.
    For example:
    cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
  3. Run the setup.sh script.
    ./setup.sh
    A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.
    WARNING:
    This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system.
  4. Complete the SDM installation and press Enter to continue to the setup, where you can select your SDM installation type. Depending on the SDM installation type you choose, refer to the Typical Installation, Custom Installation, Easy Installation, or Headless Installation chapter for more information.
  5. Repeat the previous steps on each server node in the cluster.
  6. After the each cluster node is complete, refer to the Configure the Installed Session Delivery Manager Cluster chapter for more information on associating the cluster nodes that you installed with each other so that they can function together as a cluster.
