Configure Entity Certificates
- Select option 9, SBI TLS configuration. Press Enter to continue.
- Select option 1, Entity Certificate. Press Enter to continue.
- Select option 1, Create Entity Certificate. Press Enter to continue.
Enter the certificate details.
- Common name
- Organization unit
- Organization
- City or locality
- State or province
- Country code
- Key size
- The number of days during which this certificate is valid
After creating an Entity Certificate, new options appear. -
Select the action you wish to perform.
- View Entity Certificates
- Export Entity Certificate
- Generate Certificate Signing Request (CSR)
- Import Signed Entity Certificate
- Delete Entity Certificates
- Return to Main Menu
- If you select the option to export the certificate, import a certificate, or generate a CSR, provide the absolute path to the file.
- When finished configuring the entity certificate, select option 6, Quit and back to Main Menu. Press Enter to continue.
