Start the Custom Installation
- Login to the server as the root user.
Navigate to the
Oracle Communications Session Delivery Manager installation bin directory.
For example:
cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
Run the setup
application with the setup.sh script.
./setup.sh
A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.WARNING:
This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system. -
Select option 2,
Custom. Press Enter
to continue.
[ ] 1 - Typical : Runs through most common set up options. (Recommended) [Default] [X] 2 - Custom : Allows manual customization. (Advanced users) [ ] 3 - Easy-Install : Prompts user for minimal setup option values. [ ] 4 - Quit : Finish and quit setup.
Enter Yes to
continue.
The following main custom installation options appear:
[X] 1 - Enter Passwords for default user accounts that will be created [Default] [ ] 2 - Global identifier configuration [ ] 3 - Web Server configuration [ ] 4 - Fault Management configuration [ ] 5 - Mail Server configuration [ ] 6 - Cluster management [ ] 7 - Route Manager Central configuration [ ] 8 - SAML Single sign on configuration [ ] 9 - SBI TLS configuration [ ] 10 - Oracle DB OCSDMDW configuration. Please drop this DB, if it already exists. [ ] 11 - Quit setup
Option 8, SAML Single sign on configuration for importing self-signed certificates into the Route Manager certificates file (cacerts), is not supported in this release.
