Mail Server
If you want Session Delivery Manager products to send out emails, you can setup the mail server credentials to enable the sending of emails to a targeted Microsoft Exchange and Gmail server.-
Select option 5,
Mail Server configuration. Press Enter to continue.
[X] 5 - Mail Server configuration
Select option 1,
Configure mail server. Press Enter to continue.
[X] 1 - Configure mail server [Default]
Select option 1,
Configure mail server host. Press Enter to continue.
[X] 1 - Configure mail server host
Enter the DNS name of your mail server.
Provide the DNS name. Host name [] mail.example.com
Select option 1,
Mail server secure protocol. Press Enter to continue.
[X] 1 - Mail server secure protocol
Select your mail server's secure protocol.
Valid secure protocols are:
- starttls
- ssl
Customers may select none, but Oracle recommends all customers select starttls or ssl. -
Select option 1,
Mail server port. Press Enter to continue.
[X] 1 - Mail server port
- Choose a port number or press Enter to select the default port 465.
Select option 1,
Configure mail from. Press Enter to continue.
[X] 1 - Configure mail from
Enter the address you want used for the From address.
For example, if sending to Microsoft Exchange account, mailadmin@acmepacket.com. If sending to a Gmail account, mailadmin@gmail.com.
Provide the mail from. Mail from [ ] mailadmin@example.com
- Select option 1, Configure mail user. Press Enter to continue.
Enter the mail user id.
Provide the mail user id. Mail user [] user@example.com
- Select option 1, Configure mail logon required. Press Enter to continue.
Select either true or false.
Mail logon required true/false [false]
If you set the mail logon required to true, select option 1,
Configure mail logon user password. Press Enter to continue.
[X] 1 - Configure mail logon user password
Enter the mail logon user password.
Mail logon user password []
Select option 1,
Extra mail properties. Press Enter to continue.
[X] 1 - Extra mail server properties [Default]
Enter the extra mail server properties you want to configure.
The format for entering multiple mail server properties is:
property1:value1;property2:value2;property3:value3
- Select option 2, Apply new mail server configuration. Press Enter to continue.
- Select option 2, Quit out of mail server configuration. Press Enter to continue.
