Start the Typical Installation
  1. Select option 1, Typical. Press Enter to continue.
    [X] 1 - Typical : Runs through most common set up options. (Recommended) [Default]
    [ ] 2 - Custom : Allows manual customization.
    [ ] 3 - Quit : Finish and quit setup.
