Transfer the Migrated Application Database Backup to the Replica Node Manually
Use this task if you opted not to copy the migrated database archive when you migrated application data on the master cluster node when upgrading SDM from a previous release.
- Log into the replica node, shut it down and do a backup of the application database (also known as a cold backup). See the Backup Databases on a Shutdown Server section in the Session Delivery Manager Server Database Maintenance chapter of the Oracle Communications Session Delivery Manager Administration Guide for more information.
- Migrate the application data on this replica node from the backed up application database. See the Migrate Application Data on Each Cluster Replica Node section in this chapter for more information.
- Repeat the previous steps for any remaining cluster node.
