Clustered Systems: Replicated Node
Transfer the application data to each replica node (member) of the cluster system.
Pre-requisites: Ensure that you have shut down the server, downloaded and unzipped the application image file, and started the setup application on the replica node before starting this task.
Enter 1 to continue importing the database backup.
Setup has detected that database migration needs to be performed. The migration process involves backing up the existing database and then performing various operations to migrate the database to the current version. Depending on size of the existing database and the operations to be performed, this process may take up to an hour to complete, however you can cancel and rollback the process at any time by pressing the <a> key followed by <enter>. Note that database migration MUST be performed before setup can continue. [X] 1 - Proceed with database migration [Default] [ ] 2 - Cancel and exit setup Please select an option [1] 1
Enter Yes to continue.
[X] 1 - Proceed with database migration [Default] [ ] 2 - Cancel and exit setup Do you want to continue Yes/No? Yes
Enter 1 to continue.
Your existing setup is configured for a clustered environment. For your existing environment, setup must be run on cluster node 1.1.1.1 prior to running setup on any other cluster node (including this one). When setup is run on cluster node 1.1.1.1, a migrated master database archive file will be produced. If you have already run setup on 1.1.1.1 and either allowed setup to automatically copy the database archive file to this node, or have copied this file manually, please select option [1] below. Otherwise, please select option [2] below to cancel setup. Then run setup on 1.1.1.1 before running setup again on this node. [X] 1 - Specify location of migrated master database archive file [Default] [ ] 2 - Cancel and exit setup Please select an option [1] 1
Enter the full path to the database backup and enter yes to continue the import process.
Enter migrated master database archive file path: [ ] /home/myuser/ColdBackup_2012_02_13_112911_db.tar.gz [/home/myuser/ColdBackup_2012_02_13_112911_db.tar.gz] backing up existing database....done restoring the migrated master database...done Restore migrated master database archive succeeded Press <enter> to continue with setup
- Press Enter to continue the Typical Installation and later the Custom Installation of Oracle Communications Session Delivery Manager (depending on your installation requirements of Oracle Communications Session Delivery Manager). These installation(s) must be completed to use the current Oracle Communications Session Delivery Manager software version on this replica node system.
- Repeat the previous steps if you need to transfer application data on another replica node (member) of the cluster system.
- Press Enter to continue the Typical Installation.
