Running Setup
- Login to the server as the root user.
Navigate to the
Oracle Communications Session Delivery Manager installation bin directory.
For example:
cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
Run the setup
application with the setup.sh script.
./setup.sh
A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.WARNING:
This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system. - continue.
- Complete the SDM installation and press Enter to continue to the setup, where you can select your SDM installation type. Depending on the SDM installation type you choose, refer to the Typical Installation, Custom Installation, Easy Installation, or Headless Installation chapter for more information.
