Session Delivery Plug-in Support
The Session Delivery (SD) Plug-in for Release 1.0 supports Oracle Communications Session Element Manager, Oracle Communications Report Manager, and Oracle Communications Route Manager applications.
Once the SD plug-in is installed, you can access the following Session Element Manager sliders:
- Dashboard Manager—The dashboard summary view of at-a-glance status and key performance indicators for your managed devices.
- Device Manager—Use this slider to simplify the management of small to large networks of devices.
- Configuration Manager—Use this slider to do the following:
- You can select from the following distinct configuration view styles that display a hierarchical view of infrastructure elements and their physical and logical components (for example, physical interface, virtual interface, realm, signaling service, session agents, and so on).
- View the local configuration, change the configuration and push these changes to a device.
- Use the Global Parameter, Offline Configurations, and Reusable Modules folder nodes to make configuring devices easier and manage software for multiple networks.
- Use the features in the Configure archive folder node to perform automated and manual configuration backup for a device and restore configurations to a device from the archive.
- Performance Manager—View SNMP, IP, environmental and other performance statistics collected from product devices.
- Report Manager—Schedule and run dynamic reports on NF device group(s) in your network.
- Route Manager—Update local route table (LRT) data on NF device group(s). You can also provision large LRTs across multiple devices for numeric-based routing.
