Enterprise Plug-in Support
The Enterprise (enterprise1.0_Package.zip) Plug-in for Release 1.0 contains element managers for the Oracle Enterprise Session Border Controller (E-SBC) and Oracle Enterprise Communications Broker (ECB) products.
Enterprise Session Border Controller Support
E-SBC product devices are supported by the Oracle Communications Session Element Manager, Oracle Communications Report Manager, and Oracle Communications Route Manager applications. From the GUI, you can launch the E-SBC login page and perform operations on the E-SBC except for loading the E-SBC configuration when the selected E-SBC is operating in the Basic Mode. Once the Enterprise plug-in is installed, you can access the following sliders:
- Dashboard Manager—The dashboard summary view of at-a-glance status and key performance indicators for your managed devices.
- Device Manager—Use this slider to simplify the management of small to large networks of devices.
- Configuration Manager—Use this slider to do the following:
- You can select from the following distinct configuration view styles that display a hierarchical view of infrastructure elements and their physical and logical components (for example, physical interface, virtual interface, realm, signaling service, session agents, and so on).
- View the local configuration, change the configuration and push these changes to a device.
- Use the Global Parameter, Offline Configurations, and Reusable Modules folder nodes to make configuring devices easier and manage software for multiple networks.
- Use the features in the Configure archive folder node to perform automated and manual configuration backup for a device and restore configurations to a device from the archive.
- Performance Manager—View SNMP, IP, environmental and other performance statistics collected from product devices.
- Report Manager—Schedule and run dynamic reports on NF device group(s) in your network.
- Route Manager—Update local route table (LRT) data on NF device group(s). You can also provision large LRTs across multiple devices for numeric-based routing.
Oracle Enterprise Communications Broker Support
ECB product devices are supported by the Oracle Communications Session Element Manager application. From the GUI, you can launch the ECB login page and perform operations for ECB product devices. Once the Enterprise plug-in is installed, you can access the same Session Element Manager and Session Delivery Manager sliders that you can for the E-SBC product with the following exceptions:
- You cannot load the ECB configuration with Configuration Manager.
- You cannot use the ECB in Report Manager and Route Manager.
- You cannot modify user group privileges for the ECB in Security Manager.
