EnterpriseExt Plug-in Support
The EnterpriseExt (enterpriseext1.0_Package.zip) Plug-in for Release 1.0 contains element managers for the Oracle Enterprise Interactive Session Recorder (ISR) and Oracle Enterprise Operations Monitor Users (EOM) products.
Oracle Enterprise Operations Monitor Support
EOM product devices are currently supported by the Oracle Communications Session Element Manager application in
Device Manager only. There is no support for the EOM in any of the other SEM sliders. Once the EnterpriseExt plug-in is installed, you can launch the EOM login page and perform operations in the GUI for EOM product devices in
Device Manager where you add and manage devices and device groups with the following exceptions:
- SEM does not support applying work order administration to the EOM, even though a work order displays the EOM as a selection.
- SEM does not support the Show Details functionality for the EOM.
Oracle Enterprise Interactive Session Recorder Support
ISR product devices are currently supported by the Oracle Communications Session Element Manager application in
Device Manager only. There is no support for the ISR in any of the other SEM sliders. Once the EnterpriseExt plug-in is installed, you can launch the ISR login page and perform operations in the GUI for ISR product devices in
- SEM does not support applying work order administration to the ISR, even though a work order displays the ISR as a selection.
- SEM does not support the Show Details functionality for the ISR.
