Removing an Associated Device
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC) and the Enterprise Communications Broker (ECB).
  1. Expand the Configuration Manager slider, and click Devices.
  2. In the Managed Devices table, click Add devices.
  3. In the Devices associated with Element Management pane, expand the folder hierarchy in the Targeted devices table, and click the network function (NF) device you want to remove.
  4. Click Remove.
    Your device is no longer associated with Oracle Communications Session Element Manager and appears in the Device list pane.
  5. Click OK to apply the changes.
