Overview
Depending on your user privilege level, or privileges set for the User Group to which you belong, you can manage the configuration archive.
See Security Manager in the Oracle Communications Session Element Manager if you need to change your privileges to allow you to manage the configuration archive.
For Oracle Enterprise products, the Configuration Archive supports only the Enterprise Session Border Controller (ESBC) and the Enterprise Communications Broker (ECB).Note:
A configuration can exist on every node of a device cluster. When a configuration file is pulled from a device by a node, the file is sent to all cluster nodes.
