Create Data Variables to Support Device Specific Values
Data variables can be created in the offline configuration, which are used to set device-specific values within the device cluster. Later when the offline configuration is applied to devices in the device cluster, the user is prompted to enter specific values for each parameter that is identified with a data variable.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).
in the upper right of the configuration body panel, and select an attribute to apply a data variable. A dialog appears if the targeted attribute supports DVs. The following table describes the required entries:
