Load an Offline Configuration
Use this task to configure, modify, and edit parameters for your offline configuration for your system domain.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).
  1. On the Configuration Manager slider, choose Configuration tools > Offline configurations.
  2. In the Offline Config tab, choose the offline configuration that you want to use from the table, and click Load.
  3. In the Success dialog, click OK.
    The system expands the configuration navigation tree under the Offline Configurations folder in the navigation pane. You can use this navigation tree to get to the required configuration elements.
  4. Navigate the offline configuration and configure, modify, and edit parameters in your offline configuration.
