Add an Offline Configuration by Copying a Template
Use this task to copy an existing offline configuration or a pre-packaged offline configuration template to make a new offline configuration for your domain.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
