Add an Offline Configuration from a Software Version
You can seed a configuration from a supported software version schema.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
