Create an Offline Configuration from a Managed Device
You can seed a configuration from a from an existing managed device configuration.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
